Orthographic view
Orthographic view
umitsukorkmaz
Orthographic view
umitsukorkmaz
Hello everyone, i have a homework due tomorrow i completed thé first 4 exercise but i am struggling with the fifth one can someone help please? Thank you so much in advance.
Patchy
Will this help you to finish the orthographic view?
umitsukorkmaz
Are the bottom two ones same? I am sorry my brain can not comprehend 3D views 😭
Patchy
No, just showing how tall of each part before I sliced the middle part.
umitsukorkmaz
Oh okay thank you so much 🥰
paullimapa
I’m assuming you’re talking about getting a 3d view. If you’ve drawn the object in 3d then use the View command to set current one of the predefined isometric views
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-232D690A-BA50-4E73-8EA1-E5A0812310D3
Paul Li
IT Specialist
@The Office
Washingtonn
It may be that the purpose of the exercise is to complete everything in 2D instead of 3D - yes, I understand AutoCAD makes it easy to generate a solution and manipulate views in 3D but the PNG file provided indicates a 2D isometric grid to the right of the three 2D views.
Being able to visualize and sketch a 2D representation is a valuable skill - especially when in the field where may not have access to CAD programs (or if the power fails).
A 2D field isometric sketch also requires planning of the layout.
