orginal dimension to move solve unautomatic
Y_q_12Z64F3
Y_q_12Z64F3
After the new DWG arrived, I wanted to adjust the size myself. I was surprised by the automatic size. The non-automatic size should be the original. What do your think?
turkish.
yeni müşter geldikten orjinal ölçüleri bir move kaydıraken hata veriyor otomatik istemiyorum orjinal ölçüler move olsun.
imadHabash
Hi and Welcome to AutoCAD Forum,
So that it is not subject to speculation and conjecture and to give you exact answer, your question is still unclear and needs a correct translation. Can you rephrase the question?😅
Imad Habash
imadHabash
I go to the Turkish Forum and found the same post there. Also they ask you there to give more details and elaborate more your issue. Please, don't hesitate to come back and give more details, You're welcome here and there.
Translated to Turkish ...
Türkçe Forum'a gittim ve orada da aynı gönderiyi buldum. Orada da sizden daha fazla ayrıntı vermenizi ve sorununuzu daha ayrıntılı anlatmanızı istiyorlar. Lütfen geri dönüp daha fazla ayrıntı vermekten çekinmeyin. Her yerde beklerim.
Imad Habash
Y_q_12Z64F3
yes. It doesn't work to load another member (my social account). It doesn't work again. I tried something else. I have a workplace account and it works. I don't understand.
pendean
Community Legend
Community Legend
@Y_q_12Z64F3 You will need to share your actual DWG file here please to help you address why your dimension override text changes when you move it and/or edit it in place.
Y_q_12Z64F3
ı want stretch but orginal dimensions after unautomatic dimenisons error. adding dwg
