Announcements
Ordinate dimensions in a rotated viewport
Dennis.Meehan
Dennis.Meehan
Trying to use ordinate dimensions in a rotated viewport but the dimensions are incorrect. Is there a way to use ordinate dimensions in a rotated viewport. An unrotated viewport and they work fine but if I rotate the view those previously placed dimensions change. Any tips
pendean
Community Legend
Community Legend
can you share your DWG file here? Explain how to replicate the problem in it.
Dennis.Meehan
I would have to get approval to share the drawing. I'd seen a few other comments surrounding this issue and hoped coming here would get closer to a solution. I would prefer to have the dimensions in paperspace but on rotated viewports the ordinate dimension will only provide accurate drawing coordinates when the dimensions are placed in model space through the viewport. It is a coworkers drawing of a site plan that has a user coordinate system. In model space the coordinate locations are good but if a viewport is rotated the ordinate dimensions do not provide the ucs coordinates from model space. I assumed the behavior was typical for rotated viewports and I was missing some option or setup that needs to take place to use them in a rotated viewport? As a workaround these dimensions are getting placed in modelspace. Not ideal but gets the job done...
dany_rochefort
Ordinate dimension will work just as well in a rotated viewport.
If your ordinate dimensions are wrong, than your UCS origin has been moved to another location. Keep in mind that your UCS origin must be set to where your 0,0 ordinate dimension is, so that autocad knows ''where to begin''.
If you are detailing multiple ''ordinate'' layouts or parts in 1 drawing, then you will have to move your UCS origin w each new part you detail.
To move it, type USC, then hit O for origin, and move to the correct location. You'll be good to go.
Dennis.Meehan
The ordinate dimensions if placed in model space provide the correct coordinates. If placed in paperspace they provide the X or Y coordinate as if the object was rotated and not just the viewport. it is like I need to set an angle for the ordinate dimension but I don't see where to do it.
dany_rochefort
If you are needing to ordinate at an angle, then rotate your UCS as follows:
Type the following:
USC
  (choose the Z axis)
45  (choose the rotation degrees needed)
Enter
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
