In a Standalone license ...
When you set options from Tools-> Options-> Files ... These options are saved in that file ?? You can edit from outside of AutoCAD to avoid having to change from each workstation ??
Solved by Darin.Green. Go to Solution.
This information is saved in the registry "HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R21.0\ACAD-0001:409\Profiles\<<Unnamed Profile>>\General" in the ACAD key
That being said, what you should do is export the profile from the Profile tab within Options. That will produce an ARG file which you can send to your users or host on a server share and point the desktop shortcut to that file to load in the paths and settings.
Hope that helps.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Also, once you have the ARG file, you can open it with notepad (NotePad++ would be better) to make changes.
Darin Green
