hello users.
I want to select only the opjects in my drawing while I select using the mouse, but when i do that it also select the Xrefs in the background.
Is there a way to overcome this?
thanks in advance.
HI,
i suggest to make a certain layer for your xref's then try to LOCK ( LAYLCK command ) that layer to avoid any selection matter . also there are many ways to select objects depending on their properties like SELECTSIMILAR , QSELECT commands .
Command: SELECTSIMILAR
Select objects or [SEttings]:
Imad Habash
And Then I will always do that when i create another drawing?
Nothing I can change in setting?
you cn try to use FILTER. thanks
other than the ways that i mention it in my previous post , how about while selecting use Shift+Select mouse button to remove the xref from your selection . or type R ( Remove ) while selecting .
Imad Habash
There are some tricks on how to make xref unselectable (like passive underground.). You could put in into Defpoint layer and freeze layer 0.
Or you could use THIS addon and manage the visibility a selectability using a dialog.
Sure, the most simple is just lock xref layer. xref is still selectable but in the following process is excluded for changes.
@ВeekeeCZ wrote:
.... You could put in into Defpoint layer and freeze layer 0. ....
Well.... Yes, that would make it un-selectable [also if Layer 0 is merely turned off -- it doesn't need to be frozen], but of course it would also not Plot, which I don't think would very often be wanted. You would have to remember to change its Layer every time you want to Plot, and then change it back to make it un-selectable again.
@imadHabash wrote:
.... make a certain layer for your xref's then try to LOCK ... that layer to avoid any selection matter . ....
That would not make it un-selectable.
