AutoCAD Forum
Opening up AutoCAD 2000 DWG & saving in AutoCAD 2015
1 REPLY 1
467 Views, 1 Reply
WHEN I OPEN UP AUTOCAD 2000 DRAWINGS USING AUTOCAD 2015 IT PROMPTS ME IT IS IN WRITE PROTECTED MODE.
WHEN I MAKE CHANGES TO THE DRAWING I CANNOT SAVE THEM .
IT GIVES ME I DO NOT HAVE PERMISSION TO SAVE THE FILE ASK ADMINISTRATOR FOR PERMISSION.
I DO NOT KNOW WHAT TO DO.
THANKS
JASON
1 REPLY 1
Alfred.NESWADBA
welcome @forums.autodesk.com!
Start Windows Explorer, select the file, right-click and look to it's options.
Either it's write protected here ... or if you look to he security settings in the same properties-dialog you might have restrictions that disallows overwriting the file.
I would not see that as an issue of AutoCAD, it's how the file is protected by your operating system.
Another option: when you have opened the drawing run command _SAVEAS and give the file a new name and store it into a folder where you are allowed to write files.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Technology Administrators
