I have a question regarding Radan. I know this isn't a Radan forum but it involves Autocad.
I use Autocad to create 2D drawings. I always use model space for my drawing drawn at 1: & paper space for my drawing sheet using viewports to scale the drawing in model space (others in my company don't understand paper space so do everything in model space). This is the way I've always been led to believe Autocad works. Why else would there be paper space!!! I always therefore save my drawings in paper space mode.
We have a department that uses Radan to do whatever Radan does. If they open a paper space drawing most of the information in the drawing sheet ( a block ) is missing and the drawing is scaled down in accordance with the drawing scale. If they open a drawing created in model space this doesn't happen
I can understand the scaling issue because drawing sheet is always 1:1 but the viewport scales down the drawing in model space, but I'd have expected Radan to be able to see the full size drawing in model space.
Does anyone send paper space drawings to be opened in Radan and if so how is this problem overcome without resorting to having my drawing sheet in model space?
Solved by sbromley. Go to Solution.
What is Radan?
And what is your ultimate goal?
What is Radan?
You should not use your sheets, rather just a model space dwg. And save your autocad dwg to 2013 format. Any better results?
I do save as Autocad 2013 The sheets are the same whether in paper or model space. A drawing without a drawing sheet isn't a drawing.
The guys that use Radan have finally logged a support cal. I'll see what they make of it.
