Opening a drawing template as a layout
ishmaela8
Message 1 of 8
ishmaela8
Good night, I would like to learn how to open a saved drawing template as a new layout?
Replies (7)
Message 2 of 8
imadHabash
>> I would like to learn how to open a saved drawing template as a new layout? <<
your question still need more and more to understand what you need . maybe SAVE AS command will help or Ctrl+N will help to use a new template files . please try to describe more your issue ?
Regards, 🙂
Imad Habash
Message 3 of 8
ennujozlagam
hello, you can saveas > .DWT. please describe more as mentioned above. thanks
Message 4 of 8
cadffm
If you draw a frame and title in Modelspace.
Perfect is with attdefs..
Saveas dwg
You can INSERT the dwg AS Block. Command Insert[Browse]
But a real Layout as Template:
Create your Layout(Layout tab) save as dwg or dwt.
Import this Layout by Designcenter or command Layout, option template.
Perfect for new drawings too:
Create a file with your styles, Layers and Layout.
Saveas dwt.
Set QNEW to this file and start a new file by QNEW
(Or NEW, and select this dwt)
Sebastian
Message 5 of 8
dbroad
Either right click on a layout tab and choose "From template" or use the LAYOUT Template command.
Right click layout tab menuRight click layout tab menu
Architect, Registered NC, VA, SC, & GA.
Message 6 of 8
ishmaela8
Well I was actually referring to using the layout of the first drawing sheet as a template and using it for the other supporting drawings of the same job. Then a local pro told me to right click on the layout tab then go on move or copy, then- press move to end, then create a copy. So in this way you can get new pages with the same sheet layout- which you can rename appropriately.
Message 7 of 8
ishmaela8
Hi pro, can you direct me to or send me some free window blocks in elevation.
Email is      [email protected]
Message 8 of 8
dbroad
For architectural windows, I use either a manufacturer's downloadable content if using AutoCAD. (See Andersen or Pella).  Otherwise I use AutoCAD Architecure content.
