- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Good night, I would like to learn how to open a saved drawing template as a new layout?
¡Resuelto! Ir a solución.
>> I would like to learn how to open a saved drawing template as a new layout? <<
your question still need more and more to understand what you need . maybe SAVE AS command will help or Ctrl+N will help to use a new template files . please try to describe more your issue ?
Regards, ![]()
Imad Habash
hello, you can saveas > .DWT. please describe more as mentioned above. thanks
Sebastian
Either right click on a layout tab and choose "From template" or use the LAYOUT Template command.
Right click layout tab menu
Well I was actually referring to using the layout of the first drawing sheet as a template and using it for the other supporting drawings of the same job. Then a local pro told me to right click on the layout tab then go on move or copy, then- press move to end, then create a copy. So in this way you can get new pages with the same sheet layout- which you can rename appropriately.
Hi pro, can you direct me to or send me some free window blocks in elevation.
Email is ishmaela8@gmail.com
