Open From Vault - default to $ folder?
Neil_Cross
Mentor Mentor
Neil_Cross
Does anyone know what you have to do to get Open from Vault to default to the $ root folder instead of perpetually remembering the last folder you browsed to?
This is a problem because the search tool only searches that sub-folder, you have to change the context manually to the $ folder every time you want to search the full Vault for a file.
Cheers!
john.vellek
Hi @Neil_Cross,
I don't work in Vault so I don't have a ready answer. I am inviting @reidmatthew to the discussion to see if he might be able to offer some insight.
John Vellek
reidmatthew
Autodesk Support
Autodesk Support
Hi @Neil_Cross . I have tested this with my Vault and Inventor 2019 and am seeing the same behavior you describe. I do not know of a way to change where the Open From Vault dialog defaults to. I will do some looking and asking on my side. But in the meantime, another option may be using the Advanced Search instead of the basic search on the left-hand side. The Advanced search seems to default to a higher level in the Vault so other aspects of Vault like Items can also be searched. It is a couple of extra clicks, but it will give users the power to do searches across the Vault.
Matt R.
Product Support Specialist, Data Management
Neil_Cross
Thanks guys - I was aware that the advanced search was available but it's no quicker than using those couple of clicks to change the "Look In" field to $... both options have to be done every single time a user searches for something.
Never mind, I was hoping there would be some kind of reset switch for it but obviously there isn't.  Cheers for looking into it.
reidmatthew
Autodesk Support
Autodesk Support
@Neil_Cross Just wanted to let you know I have followed up with the Vault product team and this would need to be submitted to the Vault Ideas Forum as a feature request to get this behavior changed in a future release of Vault. Let me know if you have any questions about this process.
Matt R.
Neil_Cross
Yea I'm alright on that actually, I'll pass.  One of my death bed regrets will be wishing I never spent as much time as I have done writing Vault Idea Station posts.
I'll just tell the users it can't be done.
Cheers
Neil.
