Open AutoCAD file
Open AutoCAD file
GHASEM_ARIYANI
Advisor Advisor
Open AutoCAD file
GHASEM_ARIYANI
hi
I have a problem in AutoCAD.
When I open any files saved in AutoCAD, AutoCAD runs separately for opened file.
But I need to run AutoCAD once.
How do I fix?
thanks
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Alfred.NESWADBA
The screenshot you showed is no proof that there are more sessions of AutoCAD started, it's just the option of the Windows task bar to switch between documents in applications.
Open the task manager and look how many "ACAD.EXE" you find in prcocesses.
If you find more than one process for AutoCAD then look to the system variable SDI, if should be set to 0.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
GHASEM_ARIYANI
hi
thanks alfred Dear.
