only one color is not printing but other color is printing
Message 1 of 10
when i tried to print autocad file only red color is not printing but other color is printing and my printer has all the color. red color is coming blur.
Replies (9)
Message 2 of 10
imadHabash
>> when i tried to print autocad file only red color is not printing but other color is printing and my printer has all the color. <<
i suggest to check the follow :
  • check your ctb file that the red color is ( Use object color ) . see below image
  • ...OR you may need to change your RED color from Index color to True color . see below image
Imad Habash
Message 3 of 10
i triyed your way, but it stil not coming full red. my printers color is all ok
Message 4 of 10
imadHabash
you may need to clean your printer heads and make some calibration ... you can do that from the printer settings.
Good Luck...
Imad Habash
Message 5 of 10
see here says printheads is good
Message 6 of 10
Alfred.NESWADBA
what happens when you print to PDF?
  • Is the PDF then having a blured red color?
  • When you print the PDF to your printer ... how's there the red output?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 7 of 10
when i print from pdf file is the same. red color is blur
Message 8 of 10
Alfred.NESWADBA
So if you look to your PDF on your computer red looks fine?
In that case I would say it is not dependent from AutoCAD, try to create red thin lines in MS-Word or MS-Excel and print that to the device, I guess it's blured too.
- alfred -
Alfred NESWADBA
Message 9 of 10
yes you are right. now do you have any solution?
Message 10 of 10
Alfred.NESWADBA
  • Clean your printers ink system
  • Change the printer drivers or reset settings in the driver (like used color methods)
  • Try another printer.
I guess that is now more for forums about your printer device.
- alfred -
Alfred NESWADBA
