only 1 drawing per autocad sestion
marc_vandergroep9XQVM
Message 1 of 8
Hello and good morning,
Im working with M-files and autocad 2024.
When i open a autocad, im getting the screen with the recent opened files.
When i'm going to m-files or go to my local drive and i double click on a DWG file, autocad opens an news session. so i have 2 times autocad running.
When i double click another DWG file another session opens.
When i open the first autocad session and than drag de second file in the tab line beside the fist drawing it works without any problem.
I already tried SDI but this is "0"
anyone an idea?
IT of Sunoco is blaming the last update of autocad but i think this is bs 😉
Replies (7)
Message 2 of 8
cadffm
file doubleclick action is controled by windows, I guess the .dwg (dxf/dwt) file extension is not linked to AcLauncher.exe.
AcLauncher.exe decide to open which program and instance should be use.
https://help.autodesk.com/view/ACD/2024/ENU/?caas=caas/sfdcarticles/sfdcarticles/Double-clicking-a-D...
Sebastian
Message 3 of 8
pendean
Community Legend
Community Legend
Unload M-Files, problem should go away.
Need M-Files? You'll have to go ask them for help.
Message 4 of 8
BhaskarMurari
Try this method:
Delete registry keys for current file association.
  1. Exit AutoCAD.
  2. Press WINDOWS-R on the keyboard to bring up the Run window, enter REGEDIT, and click OK.
  3. Delete these Registry keys:
    HKEY_CLASSES_ROOT\.dwg
  4. Reboot the computer.
  5. Associate a DWG file with AcLauncher.exe see DWG file type associativity in Windows😞
    C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe
    This should address the kind of issues.
Message 5 of 8
Thank you but m-files is were we "keep" al documents.
I need to open m-files to get to my drawings 😉
Kind regards
Marc
Message 6 of 8
The IT guy of Sunoco had done this already but he was also unsuccesfull, he is blaming autocad updates.
Thanks for the help
Kind regards
marc
Message 7 of 8
I will copy your option to our IT guy from sunoco, see if its something it will work.
Kind regards and thanks for the help
Marc
Message 8 of 8
lauri_barnhart
Hi @marc_vandergroep9XQVM,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
