one command to edit multiple instances mtext
Message 1 of 22
In the past, I've been able to type ED in the command line and thus was able to edit multiple instances of mtext. Now if I type ED and click on an instance of mtext, as soon as I'm done editing and I click out of the editor, the editor closes and I have to either double-click or type ED again to go to edit the next instance. Why? Is there a new command or something that I can use so that I don't have to double-click every instance of mtext I have?
Just in case the above wasn't clear: let's say I have a line of equipment and each piece has its own lines of mtext. I need to go in and change the mtext for each equipment piece. I don't want to have to double-click on each instance of mtext. Is there a command I can use to jump from mtext to mtext without having to double-click (or type ED) for each one?
Replies (21)
Message 2 of 22
Patchy
The old way was DDEDIT instead of MTEDIT
Message 3 of 22
GrantsPirate
I use TE which is an alias for TEXTEDIT.  Try it, it might already be defined in your acad.pgp.
This command works for all types of text.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 4 of 22
Patchy - Fine. Whatever. That still doesn't answer my question: is there a command that will allow me to edit multiple instances of mtext or dtext or whatever text without my having to double-click on each and every instance?
Message 5 of 22
GrantsPirate - thanks for the advice, but that didn't work. I still have to double-click each instance because the editor closes each instance after I'm done. I used to be able to edit text, click out of that one instance and then click ONCE in the next instance and keep on editing. But I appreciate your help.
Message 6 of 22
GrantsPirate
Did you type TEXTEDIT out to try it or just TE?  Maybe TE is defined as something else on your setup.  TEXTEDIT works great here, maybe a setting but I am not sure what that is right now.
GrantsPirate
EXPERT ELITE MEMBER
Message 7 of 22
Patchy
Unless newer version Autodesk killed DDEDIT, it's the command to do multiple edit
Message 8 of 22
GrantsPirate
Patchy - DDEDIT is replaced with TEXTEDIT command, saw that in help.
OP - make sure TEXTEDITMODE is set to 0.
GrantsPirate
EXPERT ELITE MEMBER
Message 9 of 22
Patchy
I need to upgrade my 2008 Smiley Very Happy
Message 10 of 22
Kent1Cooper
@Anonymous wrote:
.... if I type ED and click on an instance of mtext, as soon as I'm done editing and I click out of the editor, the editor closes and I have to either double-click or type ED again to go to edit the next instance. .... Is there a new command or something that I can use so that I don't have to double-click every instance of mtext I have?
You can select all the Mtext objects collectively under PickFirst mode, then in the Properties box, in the Contents slot, pick where it says *VARIES* and then pick on the little icon that comes up at the right:
For me [Acad2016 here] that then operates even better than what you describe -- when I finish editing one of them, it immediately moves to another Mtext object, already in editing mode, by itself [I don't have to pick on another].  I suppose you might consider it a "drawback" that it decides the order in which you edit them, but they're all in view so you can see which one you're editing in relation to the others, which should avoid any confusion.
Kent Cooper, AIA
Message 11 of 22
GrantsPirate
OP - I have used this lisp routine for years to automate the process a little.
TIP1011.LSP: ME.LSP  Cadalyst magazine.
; TIP1011.LSP: ME.LSP    Multiple Editing   (c)1994, Gary Goode
;;;modified 4.9.2003 to include mtext, dimensions, attdef and arctext
;This program will let you pick and edit multi text and attributes
;by window, pick or crossing using dialog boxes.
(defun C:ME (/ A B C D E F G H J K L M N P R)
   (graphscr)
   (setvar "CMDECHO" 0)
   (setvar "HIGHLIGHT" 1)
   (prompt "\nMulti-Edit is loaded ...  ")
   (setq A (ssget) B (sslength A) C 0)
   (while (< C B) (setq D (ssname A C) E (entget D))
      (setq F (car E))
      (setq G (cdr E))
      (setq H (car G))
      (setq J (cdr H))
      (setq K "TEXT")
      (setq L "INSERT")
      (setq M "DIMENSION")
      (setq N "MTEXT")
      (setq P "ATTDEF")
      (setq R "ARCALIGNEDTEXT")
;      (if (= J K)(command ".ddedit" D ""))
;      (if (= J L)(command "ddatte" D))
;      (if (= J N)(command ".MTEDIT" D ""))
;      (if (= J M)(command ".ddedit" D ""))
;      (if (= J P)(command ".ddedit" D ""))
;      (if (= J R)(command ".ARCTEXT" D ""))
;;updated with next section using textedit for most objects
      (if (= J K)(command ".ATTEDIT" D ""))
      (if (= J L)(command ".TEXTEDIT" D))
      (if (= J N)(command ".TEXTEDIT" D ""))
      (if (= J M)(command ".TEXTEDIT" D ""))
      (if (= J P)(command ".TEXTEDIT" D ""))
   (setq C (1+ C)))
   (princ)
); end me.lsp
GrantsPirate
EXPERT ELITE MEMBER
Message 12 of 22
HA! Quick, easy, understandable...perfect!! Thank you, Kenneth, you are my hero of the day!!
Message 13 of 22
Um...yeah.
Message 14 of 22
Yep, AutoCAD 2016 killed it.
Message 15 of 22
OK, now my idiot side is really kicking in...how do you set texteditmode to 0? I tried typing it in the command line and got an error message.
Message 16 of 22
GrantsPirate
you can get there by starting TEXTEDIT command, Mode, multiple or single.  TEXTEDITMODE works on 2017, maybe it is not there on earlier releases?
GrantsPirate
EXPERT ELITE MEMBER
Message 17 of 22
I typed in MULTIPLE, and it asked me what command I wanted to run multiple times. I typed in TEXTEDIT, and it worked! This is another great solution, Thanks GrantsPirate!!
Message 18 of 22
ВeekeeCZ
This basic lisp is little better then MULTIPLE... you can click aside for finishing the editing instead of ESC.
(while (setq en (entsel)) (command "TEXTEDIT" en))
Can be made as command and assigned for double click.
Message 19 of 22
ClaudioSattler
Observer
Observer
Hello! you can use the command FIND and REPLACE. Quick and easy!
Cheers!
Message 20 of 22
Awesome!
Thanks millions
lt
