- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In the past, I've been able to type ED in the command line and thus was able to edit multiple instances of mtext. Now if I type ED and click on an instance of mtext, as soon as I'm done editing and I click out of the editor, the editor closes and I have to either double-click or type ED again to go to edit the next instance. Why? Is there a new command or something that I can use so that I don't have to double-click every instance of mtext I have?
Just in case the above wasn't clear: let's say I have a line of equipment and each piece has its own lines of mtext. I need to go in and change the mtext for each equipment piece. I don't want to have to double-click on each instance of mtext. Is there a command I can use to jump from mtext to mtext without having to double-click (or type ED) for each one?
