OLE producing poor image quality compared to XREF
dave.mawston
Message 1 of 9
dave.mawston
Hi there,
I'm getting very poor image quality from OLE, compared to XREF.
Is there a way around this or is it just the nature of the beast?
XREF:
OLE:
(it's a zoomed-in part of the photo so I don't post sensitive information here)
Some context:
We're making a large amount of files with the same photos on the front/intro pages.
Using XREFs means we have a 'ball & chain' reference folder.
We are hoping to embed the common images in the template file using OLE, so a simple dwg file can be sent between different companies working on it.
Even with the reference folder using a relative path up a couple of levels, we still have to tell them where to put it.
Settings used:
OLE properties:
Publish settings:
We're using AutoCAD Map3D 2024, if that makes a difference 🙂
Thanks in advance!
Replies (8)
Message 2 of 9
Michiel.Valcke
to send files with xrefs you should use the ETRANSMIT command. That will change paths to relative and collect all necessary files in a single .zip file. So the recipient only has to unzip the file and everything will work as intended.
Message 3 of 9
pendean
Community Legend
Community Legend
To answer your question, you can't fix your OLE issue. Sorry.
Message 4 of 9
paullimapa
As @Michiel.Valcke suggested use eTransmit to automatically have AutoCAD collect all xrefs in the dwg into a single zip file. If you don’t want others to have to deal with folder structures then select the option to place everything into a single folder:
https://resources.imaginit.com/support-blog/how-to-etransmit-autocad-files-to-include-xrefs-and-plac...
Paul Li
IT Specialist
@The Office
Message 5 of 9
dave.mawston
Thanks guys, had a feeling this would be the case. I'll give etransmit a go 🙂
Message 6 of 9
Michiel.Valcke
In most places I have worked, etransmits are the norm for packing and sending .dwg's to people that cannot access your file server. Incoming files are often also not accepted if they are not a .zip (etransmit) file.
Message 7 of 9
dave.mawston
Oh right, so etransmit is more for sending via email? That would make a lot of sense, using zip etc.
We use a commonplace server to pass them back and forward, as we're often moving up to a hundred drawings at a time. Will continue as we were. Thanks for the help!
Message 8 of 9
Michiel.Valcke
etransmit is not just for sending by email, I just wanted to illustrate that in many places Etransmit is the only accepted method for transfering files.
Message 9 of 9
dave.mawston
Right, gotcha. Thanks for pointing it out 🙂
