OLE object is missing in AutoCAD
I insert an OLE object an rescale and save! But when I open the file again the object is not there! Neither is that shown in my prints! Why?
@Anonymous,
john.vellek has edited your subject line for clarity: OLE
nichkherbsman
Can you please attach the file also the inserted OLE.
What type of file your insert as an OLE
Thank you.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
Alfred.NESWADBA
Please let's start with the software you are using, then which type of OLE you are inserting 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
It would be helpful to see your file and the OLE file you are trying to incorporate into your drawing file. Is it possible to attach them or sample (similar problem) files to a post so I can take a look?
Can you also outline the steps you are using to add the OLE object to your file?
John Vellek
