please check picture, the only way I can make this work to check dimension and draw the ellipse again .
i do so many shapes like this that I need the cnc to cut but as long as line transforms. machine cant read or the spaniel stop millions time . please excuse my English
Solved by Patchy. Go to Solution.
Solved by Kent1Cooper. Go to Solution.
try to change PELLIPSE ( system variable )= 1 to Creates a polyline representation of an ellipse .
Command: PELLIPSE
Enter new value for PELLIPSE <0>: 1
Imad Habash
thanks for reply but its already on 0 I try to change to 1 and its same, i changed back to zero and tried again and same.
See >this<. A true Ellipse that is the same distance from another one at its quadrant points [which is what that routine does] cannot be the same distance from the other at every point -- it's just the mathematical nature of ellipses. That's why OFFSETting an Ellipse results in a Spline.
If you need it for something that doesn't like Splines, you can use that routine if you can accept that the distance between source and result Ellipses will vary slightly, or you can use the suggestion to set PELLIPSE so that the you draw the source as a Polyline approximation of an ellipse, if you can accept the fact that it's not a true elliptical shape.
thanks for your explanation. im OK if its variable or not same exact, for example I used alphacam before and after offset this wont happen. i tried Pellipse and still same,and when i convert the spline after offset into geometry its consists of hundreds broken lines
What you need to do is to change PELLIPSE to 1 before drawing the first Ellipse, so that it will be a Polyline, not a true Ellipse. Then the one Offset from it will also be a Polyline of far fewer vertices that in your image. But neither will be a true elliptical shape.
