Offline help
Offline help
Offline help
Hi dears! I have a 2017 autocad in my machine,whenever I click the" download offline help"in the autodesk page bellow message appears.
any help will be appreciate.
vinodkl
Here is the link to download the offline help for AutoCAD 2017 :Download & Install AutoCAD 2017 Product Help
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Grover_Puma
Hello @vinodkl  could I explain the steps that you followed to get to the link that I provide, it is that I am also looking for another program, such as civil 3d, and I want to see exactly where these offline aids are. regards
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
vinodkl
Hi @Grover_Puma
To download the offline help click on the help drop down menu
icon_help_dropdown.png located on the upper right corner and then select " download offline help. This would open the link in browser to download the offline help.
Here is the link for Civil 3D offline help:
https://knowledge.autodesk.com/support/civil-3d/downloads/caas/downloads/content/download-and-instal...
In the above URL replace "2019" to "2020" to download the offline help for 2020 version.
thanks dear! I have downloaded the offline help you mentioned,but when I run it the bellow massege appears.
vinodkl
Try this:
To resolve this issue complete the following steps.
1. If you are currently running .NET Framework 4.7 upgrade to 4.7.1.
https://blogs.msdn.microsoft.com/dotnet/2017/10/17/announcing-the-net-framework-4-7-1/
 After completing the upgrade, reboot your machine.
