Oblique dimensions
Oblique dimensions
Message 1 of 12
Oblique dimensions
I am converting my pipeline manual isometric drawings into CAD for my company, I was wondering if there was a way to set up a dims tyke that automatically aligns the dim line to the isometric line rather than having to manually enter 30 or -30 through the oblique and dimedit command after the fact. This is killing my productivity, also if I could just save these settings as a template that'd be stellar. Please keep the jargon minimal as I graduated in 2009 with my degree in a little rusty.
Replies (11)
Message 2 of 12
imadHabash
Hi and welcome to AutoDesk community,
i hope that this >> Link << will help you.
Imad Habash
Message 3 of 12
deusextechnic
I think i may have just the thing.
http://aolovciceng.com/downloads.html
Download Isometric dimensioning tool.
Message 4 of 12
imadHabash
Does your issue solved? if you need more help we're ready for it?
Imad Habash
Message 5 of 12
I am familiar with the steps within the link you posted, but what I am looking for is a shortcut. A way for me to utilize a hot key (if you will) that will allow me to set the dim settings prior to dimensioning. so I can point and click lines to dimension without having to go through a 4 or 5 step motion every time I want to correctly display an isometric dimension.
Message 6 of 12
I saw no link to download any Isometric dimension app, or is it already a program imbedded in CAD which will spring when I use the command.
Message 7 of 12
pendean
Community Legend
Community Legend
You need to create a DIMSTYLE to do this in your template file(s), then import that unique dimstyle into your working files either through a toolpalette or drag/drop using ADCENTER command.
>>>...I saw no link...>>>
If you are referring to the above link, are you not able to click through as I show here?
Message 8 of 12
deusextechnic
it is a lisp routine i wrote for a similar job. Hope it helps.
Message 9 of 12
leipengshang
I wonder how to use vba do this.any suggestion?
First,what i thought is to use "adddimroteted" but it was failed.
Then, is to use sendcommand   and use "dimedit" to do this,but I couldn't get the dimenion like lisp with "entlst".
so could anybody help?😂
Message 10 of 12
leipengshang
by looking for the oblique dimension in forum .finally i got the idea.
here is my code ,hope it could help those looking for question.
and thanks for *Tuersley, Mike, here is the link "https://forums.autodesk.com/t5/vba/iso-dims/m-p/300510"
Option Explicit
Sub testobliquedimension()
Dim pa As Variant
Dim pb As Variant
Dim ang As Double
pa = ThisDrawing.Utility.GetPoint(, "pa")
pb = ThisDrawing.Utility.GetPoint(pa, "pb")
ang = ThisDrawing.Utility.AngleFromXAxis(pb, pa)
ang = ThisDrawing.Utility.AngleToReal(ang, acDegrees)
Dim str1 As String
str1 = pa(0) & "," & pa(1) & "," & pa(2)
Dim str2 As String
str2 = pb(0) & "," & pb(1) & "," & pb(2)
ThisDrawing.SendCommand "DIMALIGNED" & vbCr & str1 & vbCr & str2 & vbCr
ThisDrawing.SendCommand "dimedit o l" & vbCrLf & 90 + ang & vbCr
End Sub
Message 11 of 12
Kent1Cooper
@leipengshang wrote:
....what i thought is to use "adddimroteted" but it was failed. ....
Perhaps only because of the misspelling?
Kent Cooper, AIA
Message 12 of 12
leipengshang
sorry for the misspelling.in vba ide it works.but can not get what i want.
beacuse vba dont have entity jig  class .by using sendcommand method to show it.but not perffect.
