Objects showing through each other with no overlap?
I have a structure in my drawing that I have covered with a very thin wall (.125in thick) and the structure shows through the wall when looking from relatively far away or at an angle. Is there any way to fix this?
john.vellek
HI Rafadeux,
Can you attach the file or include a screenshot to better illustrate the issue? Also, which version of AutoCAD are you using?
John Vellek
Patchy
Probably you should ask the Arch group, there is no wall in plain autocad.
john.vellek
Hi Rafadeux,
Are you working in AutoCAD Architecture? If so, I would be happy to have this thread moved so you might obtain more suggestions. If not, and you are creating your "wall" please attach a drawing so I can take a look.
John Vellek
