Cursor jumping when using ERASE command with PDF's in drawing
12:29 PM
I run AutoCAD 2017 with an approved NVIDIA graphics card, Windows 7, Intel Core i7 2.90GHz, 32g ram, 64bit Operation System, Dell Computer.
When I use the "MOVE" command or "Stretch", the cursor will select the line with a smooth transition between the starting point of the cursor to a point above the line or object. When I use the"ERASE" command, the cursor will jump around the line or object.
The drawing has 4 PDF attachments in the drawing as this was all the customer had on file. When I remove the PDF's the "ERASE" command returns to normal and has smooth movement.
Is there any settings that would correct this situation to allow smooth cursor movement with all commands? My DYNMODE is 0, SNAP is off, Rollover tips is 0, etc.
