Objects Missing when Plot to PDF
chelsea.mell.cm
chelsea.mell.cm
Hello AutoCAD Community!
I'm fairly new to AutoCAD, and I need some assistance.
I am trying to publish my drawing as a PDF, but one of my layers won't plot. (See screenshots). They were plotting fine before, then I had to add some things to a different layer, and now that first layer won't plot. What am I missing?
Thanks for your support!
Using AutoCAD 2017 on Win10.
-Chelsea
There are bunch of solution:
1) try another PDF plotter software such as Nitro PDF or Adobe PDF. (nitro PDF , recommended)
2) If the item that isn't plotted is a block make sure all  sub entity's layers isn't "VP FREEZE" or plot enabled.
3) make sure show annotative is enabled
use command : ANNOALLVISIBLE : 1
chelsea.mell.cm
Thank you, @Anonymous !!! I switched to different PDF software and that seems to have corrected the issue. I appreciate your input and assistance! Have a wonderful day. 🙂
