Message 1 of 8
Convert imported polyface meshes from Archicad to 3d-solids
Hello everyone,
as one of my biggest clients moved from AutoCAD to Archicad I get dwg-files from Archicad, containing polyface meshes. These meshes represent, for example, a multi layer wall with plaster/insulation/concrete wall. I tried some of the hints of the forum to make 3d-solids out of it with no success. The elements look like the one in the screeshot. I have a dwg attached if someone want to see the structure. The IFC import from Archicad works only with AutoCAD Archtecture and lasts a very long time. The data I got then were useless. It would be enough for me when the 3d-solid contains only the outer limits of this polyface mesh.
Workstation: Ryzen 9 5950x@ 4,20GHz 64 GB RAM, Nvidia RTX 4090, Win11 Prof. 24H2
Rendernode: AMD Threadripper 2990wx@ 3,20 GHz 64 GB RAM, Win 10 Prof.
Autodesk AutoCAD 2026, Revit 2026.1, 3dsMAX 2026.2, VRay 7, ForestPack, RailClone, KStudio ProjectManager, Miauu´s Tools....
