Objects in an rectangular array
If an object is duplicated in an rectangular array ,can you edit(change) these objects afterwards?
neaton
Yes, you can edit or replace the original source object by choosing commands from the Array Ribbon panel, the right-click menu, or the ARRAYEDIT command.
Change the spacing by either using the grips that appear, from the right-click menu, or from the Array Ribbon panel. To move, copy, scale, rotate, or erase individual objects in the array hold the [CTRL] key while selecting individual objects to create a sub-selection set.
To undo changes to the array choose reset array.
Nancy
