Objects going to 3d
Objects going to 3d
madhuryya_prakash
Objects going to 3d
madhuryya_prakash
Hi,I have a issue,although i start a drawing purely in 2D,somehow my lines and polylines and objects ends up going to 3d.(with random Z value).How do i ensure no lines,polylines and blocks will go to 3d even before i start drawing something on a fresh file.
I am a basic beginner in autocad.any help suggestions are much welcome.Thanks in advance!
pendean
Community Legend
Community Legend
AutoCAD is a 3D program. Are you sure all your inserted special blocks and objects are pure 2D? They all look the same from the top 🙂
Explore using OSNAPZ command in HELP, it should take the edge off as you start learning the program. In the meantime you can use FLATTEN command to bring errant lines back in check.
madhuryya_prakash
Thanks a lot.:)
