Object snap target box always on - BUG, GLITCH?
mpa-la
Message 1 of 32
mpa-la
I searched the forum and only found one unanswered question on this subject.  Sometimes my object snap target box gets "stuck" on.  I'll be in a command and think my snaps are on because the box shows up, but when I hit F3 the box stays visible whether the snap is on or off, or it opens the osnap dialog if snaps were off and I don't have any snap modes selected (super annoying after about the 20th time in 5 minutes).
I have noticed that if I change my pickbox setting from 5 to something else, then back to 5, it will work correctly for a while, but within the day, it's back to always on.
Known bug?  If so, I hope the pickbox workaround helps someone else out.
Replies (31)
Message 21 of 32
stevetamplen
@mpa-la
Did any of the posts get your problem resolved? If so, please hit the Accept as Solution button so that more community members can profit from the solution.
If not, please post back so we can continue to assist you.
Steve Tamplen
Technical Support Specialist
Message 22 of 32
mpa-la
The system variable monitor seemed interesting, but was a little overwhelming.  Who knew variables change so much in the background?  If it was a matter of a variable getting changed when I wasn't looking, I would have invested more in tweaking it, but since my problem is that the snap box is showing when the variable is already telling it not to, I kind of gave that up for the time being.
The last suggestion to try is a repair install, but I have been too busy to take the time to do that as my problem is an annoyance, not a deal breaker.
Message 23 of 32
stevetamplen
@mpa-la
Just wanted to check back to see if you still needed help with this issue.
Have you had more time to work on this and try some of the repair or reset suggestions?
Please do not hesitate to post back for more assistance if needed!
Steve Tamplen
Message 24 of 32
GrantsPirate
Toggle 3DOSNAP off, from ModelSpace.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 25 of 32
mpa-la
OMG GRANTSPIRATE!!!!!!  That was it! You're a genius!
Message 26 of 32
mpa-la
I wonder why I have only been experiencing this since I installed 2015...  I imagine I have accidentally hit F4 before, but I don't ever remember having a snap aperture that wasn't snapping to anything.  Certainly not constantly like it has been lately.  Weird.  This is what I get for never doing any 3D work 🙂
Message 27 of 32
Nice job on this one. It was driving me crazy.
Message 28 of 32
ragheednakkash
I HAVE EXACTLY THE SAME ISSUE AND I'VE TRIED ALL THE WAYS YOU MENTIONED BUT DIDN'T FIX THAT, IT'S SO ANNOYING, IT HAS BEEN FIXED WHILE BEFORE WHEN I WAS TRYING, BUT SUDDENLY THE ISSUE CAME BACK NOW, I USED TO HAVE THE OPTION "DISPLAY AUTOSNAP APERTURE BOX ON.. BUT THE BOX SHOULD TURN OFF WHEN F3 IS OFF WHICH IS NOT HAPPENING NOW.
Message 29 of 32
mpa-la
Did you try toggling F4?  That was my problem, it's 3d snap and it's aperture looks just like the F3 regular snap.  Watch the command line and make sure F3 says it's off, then hit F4 and see what it says.
Message 30 of 32
GrantsPirate
You must first go into ModelSpace, hit F4 or use the icon to turn 3DOsnaps off.  Now return to PaperSpace and try again.
GrantsPirate
EXPERT ELITE MEMBER
Message 31 of 32
ragheednakkash
Thanks a lot, it did fix the problem, I didn't think it might be F4 (3D Osnap), but it is. thanks mail.
Message 32 of 32
ragheednakkash
It did work., thanks Grants
