Object Snap - Geometric Center
Baz_man
Baz_man
I have cause to use the Geometric Object snap more often these days. Yes, I know it will work if one turns on the object snap (F3 among other options). However, I nornally use the object snap while in a command by pressing 'Shift - right-click' at the same time which shows a list of object snaps. The Geometric Centre option is not on there (although I thought it once was for Autocad Map??).
Is there a way to get it added?
pendean
Community Legend
Community Legend
CUI command > Shortcut Menus > Object Snap Cursor Menu
Pointdump
Hi Barry,
I've heard the Command Line Alias is >>>GCE<<<, and you might also use >>>This Method<<< to get it into your Right-Click.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Baz_man
Thanks pendean and pointdump.
I am using Civil these days and going into the CUI fixed it!
