object selection, Exploded Blocks, DWG cleanup, Pattern Recognition, PDF import
Is there a way to select objects in a drawing. So often we import PDF drawings and convert them to DWG drawings. When this happens all of the blocks explode and do not hold any property that will allow them to be easily selected. We are looking to see if AutoCAD 2019 has any commands to select similar patterns and objects that are left behind as exploded blocks. Often we will have to start with a drawing that has exploded blocks that we want to remove from the drawing to get rid of the clutter and junk. We might be using the electrical drawing but we don't want all of the lighting fixtures and whips for the fixtures as well as the receptacles. Clean up can take hours on larger drawings. There has to be a way to recognize a pattern and replace it or delete it. If you want to replace a pattern with a new block you select the objects and then the command finds all of the similar patterns. If you want to delete garbage off the drawing the Command will find all similar patterns for you so you can press the delete button after the objects are auto selected by the pattern finder. I can do this in lesser programs that only manipulate a PDF drawing. Surely AutoCAD can do this?
