Object appears but can't be selected
Hello everyone,
I'm struggling to select my object (a block) with left click on autocad.
When I do Ctrl+A, it selects everything but not this red block that you can see in the picture. The same block on the right is selected and the one on the left is the same block which I copy/paste.
I have tried PICKADD etc. but doesn't work and the layer is activated.
Can someone tell me what is the problem ?
Thank you.
Karl
pinaki.rajak
Can you please share your files, so that I can get an opportunity to check the issue . I will back to you with solutions if any.
The object was set on "PAPER" on the bottom left screen, not on "OBJECT" that is why.
Now I can select it if I change
I can't share my drawing drawing outside the company but thank you for the help !
pinaki.rajak
Not an Issue. Thank you. Best of Luck !
