AutoCAD Forum
North Direction for Geo
1 REPLY 1
tmccar
297 Views, 1 Reply
tmccar
When using online map data, what should the North direction be set to? Is this always 90 degrees? I thought this was the case, but I have imported a map of Ireland and it looks as if it's  rotated by a few degrees around the point I used as my origin.
     I work with Ordnance Survey 2D maps in Autocad a lot, and they have always been presented with North facing directly up - should  the online Autocad map not be oriented like this also? (If I enter 90 degrees ans the North orientation)
Tags (1)
Labels (1)
  • map
1 REPLY 1
Valentin-WSP
in reply to: tmccar
Valentin-WSP
@tmccar ,
Consider these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
@tmccar ,
Emilio Valentin
AutoCAD Inside the Factory
