When I do a selection in AutoCAD 2017 it is showing up in the properties as "No Selection" so I cannot change properties of multiple objects at once therefore increasing the operation of changing just the transparency of something by a hour at least?
Solved by pendean. Go to Solution.
@fkellogg wrote:
Why is this topic listed as Solved?
You'll need to ask whomever did that back in the year 2017.
@fkellogg wrote:
...I have done ALL of the fixes in the targetted article, even a brand new computer, newest version and updates, re-setting, everything.
Issue still happens at least once a week.
Only good thing is that I can save and exit, without a crash.
Why don't you start your post post instead?
AND... Here is how to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
I had a session with Volker Cocco a couple of years back.
He was very helpful, and even the reason I got a new PC.
All came to nothing, as with this issue there is no crash, and no crash report to consult.
He wanted to be granted access to poke around in my PC, but our stringent I.T. firm would not allow it.
Maybe someone else out there could get him into their system.
CFK
He wanted to be granted access to poke around in my PC, but our stringent I.T. firm would not allow it.Maybe someone else out there could get him into their system.
CFK
Tough and never easy things to try will all involve your IT folks when all things fail:
I came across this looking for an answer to another problem, but I can repeat the "No Selection" problem easily. I know this is an old thread, but there is recent activity, so for the benefit of anyone else that comes across it, I'll give my 2 cents' worth. The problem has been corrected in AutoCAD 2023 & 2024, at least the Properties Palette issue has been. (See further down for the underlying cause still being present.)
It stems from an internal limit AutoCAD has of allowing only a maximum of 128 open selection sets. Programs that don't release selection sets properly (Plant 3D is an example, even still in 2024) will also experience the problem.
To illustrate the bug, in AutoCAD 2022 or earlier (at least since 2017),
So....
AutoCAD 2023 and 2024 have fixed this bug with the Properties Palette, at least in my experience, but Plant 3D 2024 still has an issue that stems from the underlying cause. AutoCAD Plant 3D support confirmed that they could repeat this behavior. I'm still waiting for a fix.
In Plant 3D (any version as far as I'm aware):
I use the "Add to Selection" feature All the time. I've learned to use keyboard commands to do as many things as I can that would otherwise require a right-click. But "Add to Selection" doesn't have a command that can be entered at the command line, according to the support I received.
At least Plant 3D 2023 and 2024 don't have the Property Change bug any more, so I can go several hours sometimes now without having to close and re-open a drawing.
Yes, for (lisp)programming it is a known and documented limitation.
Thank you for pointing to the same by using usual "command" use.
Thank you for sharing!
Sebastian
The newest update for Plant 3D 2024 (2024.1.1) HAS FIXED THIS BUG!
I am impressed. Thank you Autodesk!
It's a known AutoCAD bug that they just won't solve.
If I'm recalling correctly it started around the 2015-2018 versions +-
I couldn't find any solutions over the years (spare yourself from re-installing it won't help)
If i can describe it - it's like a notice that the Autocad is "tired", and you should restart the software.
Soon enough after - it will crash.
I guess it has something to do with the software code being patched for over 25 years.
So - I treat it as a laid-back cry for help and refresh my session - it will go away.
But they DID fix it! AutoCAD 2023 fixed the Properties Palette bug, and Plant 3D 2024 fixed the right-click bug. Still working in 2025.
I use 2025 and just had the same issue as always. After sevral hours of working selected element shown as ''no selection'' in properties and no phisical command works (mouse+vertex related)… i got here because i had my half-annual follow-up if they fixed it and how.
Restarted the software (as always) and it's gone untill next time.
@netaoren wrote:...After sevral hours of working selected element shown as ''no selection'' in properties and no phisical command works...
You might have more going on locally that the rest of us can test and confirm. Sorry.
Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help, they can get into your computer and try to help diagnose it better for you:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Nothing local about it..
It happens on 3 different computers, old or new. . On Windowns 11 and also 10, one is 25km away from the others. On autocad 2022, 2024 and 2025.
It's the same bug as ever, they just didn't fix it.
@netaoren
Have you been able to reproduce your error with a specific step-by-step procedure? If you follow the steps in my post 47 of this thread, do you get the same error?
The "exceeded maximum number of selection sets" error is caused by code that doesn't release assigned selection sets properly. Therefore, ANY code could potentially cause this error, including add-ins, Express Tools, commands specific to verticals like Plant 3D, and, of course, custom code written by any third party or end-user. It's not necessarily an Autodesk bug that you're experiencing.
In my case, it was code that I'd written that prompted me to dig deeper. It immediately produced the error that I only saw occasionally while using Plant 3D. From pieces of code I'd come across, I assembled a routine that was instrumental in pin-pointing the exact causes of this error for my specific installation. The routine reports the number of selection sets that can currently be assigned. I'd open a drawing, run the routine to make sure I had 128 sets available, and then after some time I'd run it again. If it reported fewer available sets, then I'd know something I'd done had caused the drop. By narrowing down the time between checks I was able to determine the exact actions that would produce the error. One was any change made to an entity's properties in the Properties Palette (fixed in AutoCAD 2023), and the other was a right mouse button click when any entity was selected in Plant 3D (fixed in Plant 3D 2024.1.1).
If you're interested in pursuing the cause of the error in your systems, I'd be happy to post the routine I used. At the very least it should determine whether your issue is related to the 128 selection set limit or not.
I'm familiar with the selection limit issue, it's set to the maximum parmeter. So that's not it.
My issue (from what i can diagnose) is not related to an action or a chain of actions. The factor is time and also not in a measured repetative amont of time.
It just start once in a while after at least 2 hours of working on it/autocad being open. The solution for now is just restart the software and i'm good for the next couple of hours (or more).
I can't even upload a specific ''infected'' file because it's not specipic.. Any file that is open while this happens get the same issue and same solution (any file - even if there is only 1 line drawn in it) If i'll send you a random file it will be a ''fresh'' session and you won't see it.
This definitely sounds like a local issue.
Are all the temp folders emptied on a regular basis?
Is the temporary cache limit set to something low? Can it be raised?
@netaoren wrote:...It's the same bug as ever, they just didn't fix it.
Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
I'm not aware of a parameter that can be set. My understanding is that there is a hard-coded limit of 128 selection sets that can be open simultaneously. Please let me know what parameter it is that you are setting to maximum.
