OS: WINDOWS 10
AUTOCAD: 2015LT, 2016LT, 2017LT ,2018LT, 2019LT, 2020LT
PRINTER: HP DESIGNJET 500 BY 42 (MODEL NO. C7770B)
I'm using the Windows 10. Autocad using 2015LT, 2016LT, 2017LT ,2018LT, 2019LT, 2020LT.
Previously, there was no problem using Windows 7, but after changing the os to Windows 10, the printer cannot be specified in the plot. Currently, printers are used without problems in other programs such as PDF and EXCELL.
after seeing the existing answers such as reinstalling the AUTOCAD and reinstalling the the driver on the HP homepage, he tried various kinds of attempts for three days, but posted questions as they were useless. Is there any way you can use the HP printer in the plot?
did you install the printer driver in the computer? show some screenshot in his computer plot/printer? thanks
I don't know how to upload an image, so I just leave a comment.
My printer also appears on the list as shown in the pictur you posted. However, pressing Select does not
select the print Then, I tried to create a pc3 file using the ADD PLOTTER WIZARD in the PLOTTER MANAGER.
1. When I choose my computer, there is no print model.
2. When I select a system printer, it says my print HP DESIGNJET500 42 BY HP, but when I select it and press NEXT, an error report appears saying, "The plotter wizard suddenly shut down due to software problems."
you can reset your autocad default setting or you can do a clean uninstall and reinstall again your autocad program, it could be some files are corrupted and see if helps. thanks
