no more activation code for autocad 2007 since a few day??
 I knew by microvellum that there will be no more activation code for autocad 2007. Is it true?
cadffm
No longer activationcodes after Aug.2019,, that's true
_
1. Save the request code and the activation code well for your current system.
2. With this activation code you can install ACAD2007 again on this machine if necessary, as long as the request code is the same.
3. If you change hardware on the computer (for example, the hard disk), then there is another request code, the old activation code does not fit anymore.
4. Installing on other computer is of course also impossible, there are other hardware parts.
5. As of Sunday, Autodesk will not generate a new activation code (says the company)
See also
Previous Version Support
https://forums.autodesk.com/t5/previous-version-support/bd-p/6051
Sebastian
rkmcswain
Today and tomorrow is your last chance. Read more here.
My Windows only make an update and my request code change for no reason
Alfred.NESWADBA
If your Windows did an update today then you are using an operating system that is not supported for 2007.
I would create a virtual system with Windows XP, install and activate AutoCAD inside that system.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
