@Anonymous wrote:
Command like line? How do I do this?
I have older software here, but I think the issue should be the same....
Just to re-phrase what others have said, in the hope that you will understand better....
Type OSNAP and make sure INTersection mode is among those that are checked.
Get into some command, such as DIST if your intent is to find an angle. [Line would do, too, if you have the Status line set to report the angle as you're drawing them.] Then within that command, when it's asking for a point, hover over the vicinity of that intersection. An Object-snap marker should appear. It may be the one for something other than INTersection, depending on the characteristics of what's drawn there. The marker for INTersection looks like an X. If it's something different, TAB will cycle through the applicable Osnap modes. When the X appears, pick the point, and continue with the command.
Kent Cooper, AIA
