Nividia GTX 1050 support
Is the GTX 1050 video card is supported for 3d rendering in Autocad and Revit? Bitmap and all? Anyone using this video card?
Alfred.NESWADBA
This is the AutoCAD forum and I don't know Revit, so I can only answer for the AutoCAD side 😉
AutoCAD's command _RENDER does use only the CPU, but not the GPU, so for rendering it does not need a graphic card at all.
For using the graphic card generally in AutoCAD (and having performance with shaded styles) it depends on the version of AutoCAD you are using.
My experience is that AutoCAD can work well with nVidia GTX, From Autodesk's site you can find >>>that driver<<< (if the link does not work in your browser try a different Internet browser, for me the certified hardware site does not work with FireFox). As the drivers from nVidia are equal for a product series (as the driver shown is for GTX1070, but you asked for GTX1050) I guess that driver works well.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
