Hey Guys,
I redirected AutoCAD to a new location of our template drawing, however, AutoCAD is still going to the old location even though the new path is still shown in the "options" menu.
Any ideas?
Thanks in advance.
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
Try setting QNEW to the new template to see if that helps. Can you show me the path you have set it to?
That seemed to help it out. QNEW command brought up a window that showed the new path. Starting a new drawing created one from the new specified located.
Thanks.
