new drawing tab issue
bcsnyder2
Message 1 of 12
bcsnyder2
When i click on the plus sign at the top of the screen to open a new blank drawing it loads a huge drawing instead of my default template.  It names it Drawing 1.  If I click on the plus sign again it loads the same drawing and names it Drawing 2.   I don't know what I did to cause that nor how to correct it.  Help.
Replies (11)
Message 2 of 12
paullimapa
Perhaps follow these instructions on setting up new drawing template
Paul Li
IT Specialist
@The Office
Message 3 of 12
bcsnyder2
The first thing I did was create a new template.  When starting AutoCAD the new template is used and everything is working as it should.  It is only when I click on the plus sign at the top of the screen that this problem occurs.  AutoCAD is not using the template when creating a new tab.
Message 4 of 12
bcsnyder2
Problem solved.  I right clicked on the plus sign.  The options "New" and "Open" appeared.  I clicked on New and then chose acad.dwt as the template.  Now when I click on the plus sign the new drawing that opens is using the acad.dwt file.
Message 5 of 12
cadffm
right
The [+] uses the last used file in NEW command.
Sebastian
Message 6 of 12
CalebFG5BQ
I am having a similar issue, but none of what is described above fixes it for me. No matter what I do, when I click the plus, it seems to default to a generic autodesk template, not my custom one. Help!
Message 7 of 12
CalebFG5BQ
Nevermind, solved it 🙂
Message 8 of 12
paullimapa
Would you share your solution?
Paul Li
IT Specialist
@The Office
Message 9 of 12
CalebFG5BQ
I had to redirect to the correct path for my Default Template File Name for QNEW. Redirecting this to the template file I wanted to use fixed the issue.
Message 10 of 12
paullimapa
Message 11 of 12
CalebFG5BQ
Yes, I used your response! Thank-you for the help!
Message 12 of 12
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
