Network toolpalettes
tdavis26FDXG
Observer Observer
tdavis26FDXG
Observer
Observer
Hi everyone,
I have been trying to set up a group of networked palettes for my department. All file locations have been changed to reference the network locations, but multiple versions of each palette are being created. For example I have a Misc Blocks_7 but the latest version is _5.
Can anyone explain why this is happening and a solution to stop this. I am currently the only user that has access to them at the moment.
Tom
Valentin_CAD
@tdavis26FDXG ,
Consider the process from this link:
Related:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
tdavis26FDXG
Observer
Observer
@Valentin_CAD
I can set up the sharing for the toolpalettes, my issue is that i have multiple (2 to 3 copies of each) versions of the same palettes being imported from the network. The tool catalogs have been created within a minute of eachother and there's now a total of 6 of the AcTpCatalog files.
Do you know why the are so may of these being created and how I can stop this from continuing?
Tom
Valentin_CAD
@tdavis26FDXG ,
Not sure why there are multiple versions of the same palettes.
However, try the following:
1. Create a specific folder in the Network for the Toolpalettes (something like: N:/Standard/Autodesk/Toolpalettes)
    [This folder should contain various files including: *.atc, *.xtp, *.xpg)
    Note:  Also, verify the *.xtp files have the correct <SourceFile> path [Open with Notepad].
2. Then make sure to add that path in the OPTIONS > Files (Tab) > Tool Palettes File Locations
Emilio Valentin
tdavis26FDXG
Observer
Observer
This is how I've set the palettes up from the start.
What would you reccomend for trying to fix the issue? It creates quite a lag when first opening autocad in the morning as it loads all the tool palettes.
Tom
Valentin_CAD
@tdavis26FDXG ,
See a solution for a similar issue:
Emilio Valentin
