Need to move command line
cliffordjohnturner
Message 1 of 14
cliffordjohnturner
I've been on REVIT too long.
My AutoCAD Command Line is found at the lower-left corner of the Screen, even when I have AutoCAD display as partial screen, the  Command Line is separate from the AutoCAD display at the lower left corner of the Screen.
I set LOCKUT to "0", but I can't select the Command Line, thus I can't move it.
Also, the Command Line lasts only 5 seconds before fading away.
Any help will be appreciated.
Replies (13)
Message 2 of 14
Patchy
Hold the CTRL key down while moving it.
Message 3 of 14
imadHabash
You can learn more for Positioning the Command Window Here.
Imad Habash
Message 4 of 14
cliffordjohnturner
  This is what the mess looks like:
I can't 'select anything to move.
And the command line fades away after 5 seconds.
Message 5 of 14
cliffordjohnturner
Message 6 of 14
Patchy
Maybe the graphic driver.
You can try this:
Message 7 of 14
pendean
Community Legend
Community Legend
@cliffordjohnturner So 2018 is not new software: is it new to you, just get a new computer, or is this some very new and sudden display issue out of the blue?
For the topic you asked about... Start CUI command, select your active workspace, select palettes, then commandline, then choose one of the options presented. Don't forget to click DONE then APPLY then OK out of CUI in that order when finished.
Message 8 of 14
cliffordjohnturner
Thank you for your step-by-step instructions. I found it easy to follow, especially with the red highlights. Unfortunately, the command line is still at the lower left of the Screen. It still is outside the AutoCAD display. I've restarted AutoCAD and went through your instructions again with no change.
I am now 74 and want to thank you for taking your time to help.
I started with AutoCAD 9, decades ago, never having had this problem.
Any other ideas out there ?
Message 9 of 14
paullimapa
Can you enter command GRAPHICSCONFIG then do a screen capture and share that here?
Also have you installed:
AutoCAD 2018 Update 2018.1.2 - Autodesk Community - AutoCAD
Paul Li
IT Specialist
@The Office
Message 10 of 14
cliffordjohnturner
Message 11 of 14
paullimapa
Since you're running Directx11 and you're on 2018, you can try changing it to use Directx9 to see if that would solve your problem by following these instructions:
How to use a previous DirectX version in AutoCAD Products
Paul Li
IT Specialist
@The Office
Message 12 of 14
cliffordjohnturner
It doesn't allow me to select the Command Line, which only has text, no dotted left edge.
Message 13 of 14
cadffm
I think this is not possible, I guess you edited the wrong workspace or you forgot to apply.
Give me a try, okay?
    save your current workspace to save your current setup
1. Command: WSSAVE<enter>MCWS<enter>
    edit this workspace and use it
2. Command: CUI
    Step1 - Select the (current) workspace, what is the MCWS
    Step2 - Select 'Commandline' in Palettes node - on the right
    Step3 - Set Orientation to Top
    Step4 - Press [APPLY]
In this second, your commandline should move below your menubar.
Sebastian
Message 14 of 14
cliffordjohnturner
Your #2 did the trick.
Thanks !!!
