Need Help with Plotting Boundary Points
lrbgrenas
Observer Observer
lrbgrenas
Observer
Observer
I was given these boundary points as a reference to a lot I'm currently working on for academic use, but I can't seem to make it work. Tried to convert it to decimal degrees, but it was so small. When I tried to scale it, the area was a lot smaller than the total area of 8 hectares.
15°20'18.88"N 120°30'57.08"E
15°20'18.90"N 120°31'6.92"E
15°20'9.74"N 120°31'6.93"E
15°20'7.87"N 120°31'4.93"E
15°20'12.06"N 120°30'57.18"E
paullimapa
I think your data is missing the length...typically plot plans look like this:
In AutoCAD you set the UNITS like this:
And then you enter the info like this:
Start the ._LINE command and pick a starting point. If you have XY or Northing and Easting coordinates, you can enter them, otherwise just pick any point in the drawing. Then at the next prompt enter @107.65<N28D45'21"E
Paul Li
IT Specialist
@The Office
richard_387
I think your data is in spherical coordinates. So to plot them you need to be working in Map. I am sure you know about different coordinate systems.
However, I have not got access to such a version, so I converted the coordinates to UTM using a free coordinate converter on the web, and find the area to be 8.23 hectares.
richard_387
Or by entering the coordinates into Google Earth, you can see where the points are.
