Need help with my drawing
Hello Everyone.
I had a trial to autocad and cannot license in with limited time. I had it all drawn out and lost all my files.
Can someone help me draw this go kart on autocad?
BeKirra
@Anonymous wrote:
Hello Everyone.
I am afraid that nobody will draw it for you because it is not a technical question and it may take couple of hours to get it done.
To answer your question:
If you had drawn it and saved the file somewhere, it wouldn't be lost, no matter your license of AutoCAD is expired or not.
Do a search in your windows explorer you may be able to find it out.
In worse case, if you lost the file then you may have to hire someone.
BTW if you found the file, you'd be able to print it out - Download a AutoCAD DWG TrueViwe for free from Autodesk web and install it. You can view the drawing file.
Here is the link:
https://www.autodesk.com.au/products/dwg/viewers
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
imadHabash
>>  I had it all drawn out and lost all my files. <<
i'm curious to know that how did you draw it ? would you give us an idea that depending on what have you accomplish it ?
Imad Habash
