Effective Method Of Converting These 3D Models To 2D Nets?
Message 1 of 11
Hi everyone,
I'm converting slightly  complex 3D shapes into 2D nets for the first time. Previously I have manually drawn out my 2D nets, but I want to avoid doing it manually for fear of getting any of the angles wrong, plus in this case I have quite a few to make.
I want the 2D nets of the black and red components in the attached file. They are 0.5mm thick so I'm not sure if this poses any extra challenges.
I believe there are add-ons that can help with this, but if possible, I'd like to make my nets in default AutoCAD 2017.
I'd appreciate any recommendations!
Replies (10)
Message 2 of 11
Try XEDGES to extract the edge geometry, if you need a flat of each then use FLATSHOT.
Message 3 of 11
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 @Anonymous is pretty fast!
I was thinking that you might create a viewport with the create orientation and then use EXPORTLAYOUT to get this into 2D. That is really fast but I am not sure it works for your process. I did this with your file and I have attached it so you can examine it.
John Vellek
Message 4 of 11
john.vellek
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 5 of 11
Alfred.NESWADBA
are you speaking about sheet metal unfolding?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 11
Hi!
Sorry I couldn't reply sooner, I had been very tired up for the past couple of days. The screenshot you attached isn't what I had in mind unfortunately. Basically, I want to unfold the shapes into nets that can then be used to die cut cardboard for assembly, so that I can make the shapes shown in the CAD file in real life.
Message 7 of 11
Hi!
I'm not familiar with CAD terms so for clarity I'd like to quickly explain exactly what my intentions are:
The file is a mockup of packaging that I'd like to make in real life. I want to prototype the shapes shown in the file, so I'm trying to unfold the shapes into nets, which I can then use to die cut cardboard and assemble in real life.
Best,
Jack
Message 8 of 11
Alfred.NESWADBA
Well, that can't be done with AutoCAD itself, you need another product to do that (I think Inventor can do this) or you need a 3rd party application for that job.
Sorry, - alfred -
Alfred NESWADBA
Message 9 of 11
 Thank you, I'll check out inventor!
Message 10 of 11
What you are trying to do is referred to as a development. I haven't done these in a while but I believe this is what you're going for. Someone else from the community can probably do this much better than i can but for a general direction, is this correct?
Message 11 of 11
Yes, I'd like to do something like that, but without doubling up the walls. I increased the thickness of the walls in CAD to better visualise the model, I wouldn't want to die cut separate inner and outer walls.
