I am praticing autocad with excercise but I get stuck here, I don't know how to draw this circle
Solved by imadHabash. Go to Solution.
this graphic should give you a hint:
Agree, in reference to Inkedexercise 5.jpg there's not enough information to draw those two arcs.
Missing are radius dimension & center point locations.
Also the sizes & positions of all those 21.9 diameter circles surrounding the single 30 diameter circle are assumed to be the same size and at the same 33.5 distance from center point
Glad to have helped…cheers!!!
Do a search online
I think it's missing the location of where the center is for R15 Arc.
The circle is tangent to R60 and R80 so first find the tangent to R60 by working down from the top.
