Message 1 of 10
Need help with adding deviation tolerance
07:12 AM
I need some help with adding a deviation tolerance to normal text. I have some lines drawn in paper space that represent a feature on a model in the view port. I need to linear dimension with a deviation tolerance the lines but it obviously isn't the same dimension as the feature it's meant to represent. So when I change the linear dimension (by editing the text and backspacing) then typing for example "2.000" and add a deviation tolerance it doesn't show up (I'm assuming because it is now normal text and not what ever type of special text is created when you dimension). Is there a way to force a deviation tolerance to show up for normal text? Or is there a better way to do this?
