Need help with 3D Orbit as default with shift middle-mouse click
lorne_tontegode
lorne_tontegode
I've been using AutoCAD since version 9 but have had a few years away from solid 3D work. I'm also new to the forum.
I can't seem to figure out how to set the shift middle mouse button to Free 3D Orbit. I only work on mechanical components and the constrained 3D orbit is not working for me since I have to view my parts from all angles and it doesn't change to suit the current UCS.
I had a look at the macro by going into CUI but I don't know what the macro would be for transparent Free 3D.
imadHabash
Type CUI in command line and see if it's the same as below image ?
Imad Habash
lorne_tontegode
Thanks for replying and yes, that is the macro that is in place right now. That gives me constrained 3D orbit and I need Free 3D orbit. Is there a way to change it?
imadHabash
I suggest to take the concept as mentioned here . >> Click <<
Imad Habash
lorne_tontegode
Thanks for replying. That is how it is set up right now. It does a constrained orbit with the shift middle mouse button. I need Free 3D Orbit though
peterm
Shift + Ctrl + middle mouse button should do it.
lorne_tontegode
Thank you very much. That did it.
