Need help setting up scales and plotting (metres)
lois-pl
lois-pl
Hello, I have been having a very hard time plotting drawings with the correct scale, basically because Autocad's default scaling system doesn't work (or it's just very user-unfriendly).
  • I am making a template file.
  • I work with metres, and I only need to setup the following scales: 1:50, 1:100, 1:250, 1:500, 1:1000
  • I want to also setup an A4, A3, A2 and A1 sheets.
  • I will design everything in model in real scale (1:1)
  • I want to print "DWG to PDF" in ISO full bleed
  • Plot area must be "Layout"
  • I need to click inside the Mview and be able to setup the scale from the toolbar below
  • I also need to see my paperspace dimensions in mm, so if I measure an A4 page it will show 297x210 (mm) instead of 0.297x0.21 (m)
What happens is that when I set a scale from the toolbar like 1:100, the drawing becomes suuuper small, definitely not 1:100. I have no idea why. Autocad needs to simplify its scaling system, it has too many variables, and probably one is messing up everything.
I suppose that 1 unit is 1000mm, because 1 unit is 1m.
My default scale list has 1:100 as 1 paper unit = 100 drawing units (why??)
Please help me setup the ultimate drawing file so that I can start using it without any more trial and errors in the future. This issue has been cursing me since I started using autocad.
Thank you
PS: Online resources and tutorials are very confusing since everyone uses different systems to scale and I need to set it up how I described. I'm exhausted from doing trial and error and if something works I never really know why.
My current pagesteup
my current scale list
cadffm
these predefined sample scales are made for MILLIMETER usage
and your Paperspace is in Millimeter too (the Paper is defined in Millimeter).
3 Ways, I describ 2 of them:
1. Create own new scales for Meter usage (not prefered if you not like to use annotation feature)
2. In Layout, Viewportscale: Use 10:1 instead 1:100 (because 1m is a factor of 1000 for Millimeter), same with other scales, and in pagesetup or Plot dialog, plot 1:1  - your frame and title are drew in 1:1 Millimeter.
 (prefered if you not use annotation feature much)
OR
3. In Layout, Viewportscale: Use 1:100 for 1:100, same with other scales, and in pagesetup or Plot dialog, plot 1000:1  - your frame and title are drew in 1:1 Micrometer. (very unusual today)
The most important thing for the best recommendation would be to know whether you use the annotation function or not.
Are you familiar with this? I suspect not, otherwise the issue would have been clarified earlier,
so answer 2 is definitely the best solution.
If you don't use a annotation function, then ignore the "1:1xx" settings everywhere and just use the scaling factor.
By the way, in my answer 2, that's a factor of 10!
Why?:
1 meter in 1:100 is 0.01 meter and 0.01 meter is 10 millimeters.
The paper format is defined in millimeters, hence the conversion.
Sebastian
cadffm
  • I will design everything in model in real scale (1:1) in Meter
    This is part of a clear specification, because 1 or 1000, both are 1:1, one would be correct in meters, the other in millimeters
  • Plot area must be "Layout" second worst choice.
     If possible: Keep paperspace clean outside your frame, this way you can use EXTENTS and you will have less trouble in the future.
  • and be able to setup the scale from the toolbar below
    or select the viewport to select the scale from the gripmenu or properties-palette
    If you want to measure 297x210, you have to draw it 297x210 - see above about my 2.
Sebastian
