Need help setting up scales and plotting (metres)
- Mute
- Permalink
- Report
Hello, I have been having a very hard time plotting drawings with the correct scale, basically because Autocad's default scaling system doesn't work (or it's just very user-unfriendly).
- I am making a template file.
- I work with metres, and I only need to setup the following scales: 1:50, 1:100, 1:250, 1:500, 1:1000
- I want to also setup an A4, A3, A2 and A1 sheets.
- I will design everything in model in real scale (1:1)
- I want to print "DWG to PDF" in ISO full bleed
- Plot area must be "Layout"
- I need to click inside the Mview and be able to setup the scale from the toolbar below
- I also need to see my paperspace dimensions in mm, so if I measure an A4 page it will show 297x210 (mm) instead of 0.297x0.21 (m)
What happens is that when I set a scale from the toolbar like 1:100, the drawing becomes suuuper small, definitely not 1:100. I have no idea why. Autocad needs to simplify its scaling system, it has too many variables, and probably one is messing up everything.
I suppose that 1 unit is 1000mm, because 1 unit is 1m.
My default scale list has 1:100 as 1 paper unit = 100 drawing units (why??)
Please help me setup the ultimate drawing file so that I can start using it without any more trial and errors in the future. This issue has been cursing me since I started using autocad.
Thank you
PS: Online resources and tutorials are very confusing since everyone uses different systems to scale and I need to set it up how I described. I'm exhausted from doing trial and error and if something works I never really know why.
My current pagesteup
my current scale list
