Need help converting this wireframe into a solid
Hello, I am sorta new to autocad and I realized after getting this far into making the model I didn't know if I could even turn it into a solid which I need so I can 3d print it eventually. Any instructions on how would be very helpful thank you.
imadHabash
you just have in your drawing a polylines, lines and arcs in a 3d isometric shape . you have to start use Extrude,presspull and Loft commands that will get your final 3d solid model. you can active those commands and press F1 for help to understand well how to do it .
Imad Habash
j.palmeL29YX
Your wireframe model doesn't complete describe the geometry of a solid. There are missing some informations (lines, arcs) and some seem to be wrong drawn. Without a lot of phantasy and free interpretation it's not possible got get a solid from that.
First you have to complete/correct the wireframe model ...
Jürgen Palme
