Need a bit of extra computer power!!
Message 1 of 8
Hello there i have been using this forum for a while for helpful how to's but have come up against a problem as my computer isn't high spec'ed enough to press pull the last bit of a computer case i am designing so was just wondering if someone on here could be kind enough to press pull the bio hazard sign so that i can go off to the laser cutters with the finished piece.
Thanks in advance
Replies (7)
Message 2 of 8
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I would be happy to do this. What kind of height do you want?
John Vellek
Message 3 of 8
Thanks for the warm welcome John
I would like it to cut all the way through the same as the other bolt holes already on the drawing, the material is 4mm thick. I was just using press pull and dragging it down and it was auto sizing it to the 4mm thickness for the other holes.
Message 4 of 8
john.vellek
Hi @Anonymous,
When  I try to add thickness I discover that your objects aren't closed and that they are built from a bunch of segments that don't close. How did you create the objects? Do you have dimensions from which to recreate?
If not, I suggest that you retrace them with large arc segments so that you can get them smooth and closed.
One good test is to use the BOUNDARY command to see if it can create a nice clean and closed polyline.
Then you should be able to PressPull  even on your computer.
John Vellek
Message 5 of 8
Patchy
Try this:
Message 6 of 8
I got an image and traced it i think that's where most of my problems come from. Im going to have a read up and play around with them commands to get a feel of how they work now thanks.
Message 7 of 8
That is perfect! thank you very much. Can i ask what process you used to get this done?
Message 8 of 8
Patchy
I used the autolisp PLDIET.lsp by Kent Cooper, reduced the vertices and picked Retain the curves.
Then LOFT the symbol (Presspull doesn't work well for me) Subtract to get it done.
